!991 Old cieraTavycal 12-14-2007, 08:10 PM Check engine light is on. There are no codes stored. Cruise control doesnt work, I can not find a spot for a fuse in the fuse box for cruise control all fuses in box are good. I replaced o2 sensor,sparkplugs, fuel filter air filter. When I drive my car seems to jerk[not side to side] and the check engine light and temp light flash then the speedometer drops to zero and the check engine light stays on Temp light goes out. Temp gauge shows that I am not overheating. maxwedge 12-14-2007, 08:25 PM Cruise will not work when certain codes are stored, try and get this on a scanner, the pcms were troublesome in these years also. Tavycal 12-14-2007, 08:27 PM Cruise will not work when certain codes are stored, try and get this on a scanner, the pcms were troublesome in these years also. Thanks Did you read my previous e post? There are no codes stored. Oh are you saying that just using a jumper is not sufficient? maxwedge 12-16-2007, 04:04 PM Correct. plodder 12-16-2007, 04:20 PM Is this still carbed??I doubt it,but if it is,I had a mixture control solinoid,in a 89 olds go bad and have a similiar experience,it also would bog down on rapid excelleration. Any.. Good luck Tavycal 12-17-2007, 07:57 PM Is this still carbed??I doubt it,but if it is,I had a mixture control solinoid,in a 89 olds go bad and have a similiar experience,it also would bog down on rapid excelleration. Any.. Good luck Not carbed thanks though Automotive Network, Inc., Copyright ©2012
