My intake won't fit
howard_w13
09-25-2001, 09:56 AM
Just got a used Stillen intake from a guy in Maryland who had a 200SX.
Unfortunately the adapter is not the correct fit on the intake so I need to know where i can get the right adapter to fit my car.:help: :help:
P10DET
09-25-2001, 11:36 AM
It should fit. I don't believe Nissan changed the MAF in our cars at any time.
You may have to rotate the adpater/venturi/air horn. The holes only line up one way.
redvalkrie
09-25-2001, 12:25 PM
On the 99G20t the maf is smaller and the whole's are aligned difrent.
2000+ differ greatly. I tried them side by side luckly we had a 99 & a 2000 on hand to see if the intkaes could be crossed over & no they don't fit on each other. the MAF on the 99 P11 is smaller than the 2000+P11 & then the hole's won't align.
I am not sure of the 200sx's but you might want to try tuner shops.
What year is your G p10, p11?
howard_w13
09-25-2001, 12:52 PM
Oops. Forgot to mention its a 1995 G20.
P10DET
09-25-2001, 02:11 PM
The B14 intake should work with no troubles.
howard_w13
09-25-2001, 02:41 PM
B14? Don't know what that is. Where can I get it?
zykotik
09-25-2001, 05:04 PM
Show me a pic of your adaptor...I had the same problem so I drilled the holes to the appropriate locations and cut this square of metal that was blocking the maf from getting a reading. Until I did that the car would barely start.
P10DET
09-26-2001, 01:52 AM
200SX
I was refering to the intake you have.
howard_w13
09-26-2001, 04:21 PM
Oh, uh, yeah, I knew that. I was just testing you P10DET :D And as for Zykotic, here's a pic of the intake.
howard_w13
09-26-2001, 04:25 PM
And another pic
zykotik
09-26-2001, 05:24 PM
Yup that won't fit. The circle needs to be bigger (or the maf won't get a reading) and the holes need to be drilled elsewhere...If it stops raining here I'll take a pic of mine and show you what I had to do to mine.
P10DET
09-27-2001, 01:01 AM
I'm doubtful. I'm 98% sure the venturi for the B14 is the same as for the B13. I used a B13 Stillen intake on my P10. Same MAF.
Howard, am I right in thinking you're also in Houston?
hpro123
09-27-2001, 04:56 AM
B14 is the chassis/model designation used in the US for Sentra (or Pulsar/Sunny/Almera depending where U are) cars.
B14 == N15 == 1995-2000 Almera/Pulsar .
Chris
P10DET
09-27-2001, 08:03 AM
Originally posted by hpro123
B14 == N15
How sure are you of that? If they are the same, why do they have different platform designations?
howard_w13
09-27-2001, 09:39 AM
Close. I live in San Antonio. If need be, I can come to Houston for the next geekout and maybe some of the people there can help me put it on.
:cool:
hpro123
09-27-2001, 10:07 AM
Geo,
I am not SURE about anything. I am quite sure though that for some reason Nissan uses either the Bxx or the Nxx designation for Sentra platforms almost at will.
Beats me! Well, circumstantial evidence supporting the assertion that B(x) == N(x+1)...
1. N(x+1) production dates are same as B(x) dates.
2. I have a N14 Sunny 2.0 GTi and Nissan FSMs for both the B13 Sentra and the N14 Sunny. They are almost identical. Only differences I found (until now) were on the emmission stuff and small such in the suspension rates.
3. Family has an N15 Almera 1600 and Nissan FSMs for both the B14 Sentra and the N15 Almera. Same story, almost identical.
4. All aftermarket parts I am aware of (including suspension and bracing) and several OEM chassis parts are interchangeable between B13/N14. Same fro B14/N15.
5. The NX went to the States as B13 and in Europe as N14. This is a nice indicator since there were no sub-models etc. Just 1.6 and 2.0liter NXs using either B13 or N14.
6. Finally, I have stumbled upon various sub-designations about chasses and even those are almost identical between these two platforms.
Examples I have found:
N14, FN14, FNN14, EN14, HN14, SN14, RNN14
B13, FB13, FNB13, EB13, HB13, SB13, ??????
N15, FN15, FNN15, EN15, HN15, HNN15, SN15, SNN15, JN15
B14, FB14, FNB14, EB14, HB14, ??????, SB14, SNB14, ????
Not only that but with the exception of the Sentra designation in the US, Sunny and Pulsar seem to be the names of choice for all the aforementioned models around the world. For example we have Sunnys using the B13, N14 and B14 platforms (N15 as far as I know appears only as Almera and Pulsar).
In any case, if you know otherwise I will be more than glad to be corrected. I look forward to a major "investment" in suspension/chassis aftermarket parts the States and I will definitely need to know any difrences there might be.
Chris
howard_w13
10-01-2001, 03:19 PM
Have you had a chance to take a pic of your intake yet?
ricecube77
10-01-2001, 06:41 PM
I'm in I'm in.... for the geekout!... err.. yea.
-Phil
94' Silver P10 G20
P10DET
10-02-2001, 12:37 AM
Hehe. Me neither. :D
Very interesting info. Man, I wish I could learn more, but my little monkey brain is filling fast. Actually I have too many other things going on to get too involved in figuring this out right now. Maybe down the road..... Good info though.
Actually, I know it's not just a B13 or N14. That much I do know. The NX is a KB13 or maybe HKB13. I know for sure the B13 is powered by a 1.6 litre engine.
I think you have more info on this than me. I'm interested in knowing the particulars, but like I said, not at this time.
As for parts, what are you looking for?
P10DET
10-02-2001, 12:40 AM
:cool:
Way cool. I should be having a geekout in 2 or 3 weeks. I was supposed to finalize this weekend, but it was, ah..... strange.
Anyway, probably in 3 weeks. I'm not sure though. I will probably be in SA soon. I have to go there for a photo shoot.
hpro123
10-02-2001, 02:22 PM
Hehe. Me neither. :-))
I know the feeling but a big difference Geo. You are not sure because you tried so many you lost it!! I am not sure because I read so many I lost it!
I know the feeling Geo but I have news for you. It is this little "age" thing that precludes our brains from absorbing info! Looong time ago brain was always empty. Now it is always full and I have to get rid of "unused" info all the time. :-((
Now, just when I had it layed down nicely you have to come in and spoil it! No Ks on my list means I have to go back and update it again... Well, it will keep me busy...
Hopefully some time "Really Soon Now" I will put everything in a nice little "heritage" document and pass it around. (of course R-S-N in my case is "somewhere down the road"...)
The works. Excluding the Koni-GC combo and the ES bushings & inserts I have a bone-STOCK and without the emmisions stuff you guys get over there. My car is speced to the US87 emmisions specs (no EGR-BPT) meaning I have a nice little platform.
So in order of importance I will get...
Rear STB (probably from Whiteline Australia)
N-Tech Under brace
Rear Sway-Adjustable
Front Sway adjustable (not needed but what the heck)
Shortened coilovers all around + GC Camber/Caster plates
CAI-Headers-Exhaust
S3_JWT ECU (maybe)...
Excluding the Exhaust, all the rest have to come from the US or AU.
Particularly in the coilover issue I am always open to suggestions. I never figured out whether the cost of shortened struts is justified over the KONI-GC combo I already have...
Take care and do not stress your brain too much! It's all downhill from here on (at least that's what physiology says). :D
Chris
howard_w13
10-02-2001, 04:11 PM
If you come to SA, let me know maybe a day or two in advance.:cool:
