01 T&C speedometer dead
farmer11
12-14-2007, 08:28 AM
The speedometer on the 01 T&C does not move at all. Everything else works and no warning lights are on. Where do I look for the connections at?
Thanks
RIP
12-14-2007, 06:33 PM
Hold the trip odometer reset buttons or button in for 5 seconds. The instruments should cycle through a test. If the speedo cycles, it's good. If it doesn't cycle you'll need a new instrument cluster. If it does cycle, it points to the output sensor on the tranny or the wiring between.
brocsbar
06-26-2008, 05:37 PM
many caravans have this problem and if you let it go your guages and spedo etc wont work. take out the 4 screws that hold on the a/c stuff and unplug it and inspect for a burnt terminal I JUST did one 5 min ago. Clean it up and plug back in or get one from the junkyard
