1994 Cutlass Supreme 3.1 Starter Removal
classclown
12-12-2007, 06:27 PM
Hey, Im having some serious problems removing the starter in my cutlass surpeme. I replaced the alternator a couple of weeks ago with no problems. I removed all of the wires from the solenoid and that is about as far as I got. I can't seem to find where these 2 or 3 bolts are that hold the starter in place. Can someone tell me where to find these bolts or give me some better instructions on how to replace it?
maxwedge
12-12-2007, 07:36 PM
Welcome to AF, try autozone.com, repair guides for basic info.
3100MPFI
12-17-2007, 08:57 PM
There is only 2 bolts that hold the starter in place.
First of all, there is a BLACK COVER that is held on with 10mm bolts. I think there is 3 of the, but there might only be 2. Once you get that cover off, you can get to the 2 bolts from UNDER the car. The 2 bolts go straight up into the starter from the bottom. One is in front of the subframe, the other you can get to between the subframe and the engine.
