Re: Strut Noise
I basically detached the entire strut starting with the 4 screws under the hood (not the center nut) and i also detached the strut from wheel so that it all comes out in one piece. Next u have to compress the spring tight enough so that when you take the center nut lose, the bearing plate just comes off with ease. You will know if you do not compress the spring enough because the plate won't fit on. Thus you will have to compress the spring more until u can fit it on. I.E...compressing the spring was a bitch but it can be done.
