Re: 99 Camry dome lights / clock not working help
My guess would be that the sun roof motor connections have corroded to the point where they don't work. Ditto for your door open switches to turn on your dome light. I just finished taking apart and cleaning the door open switches for the dome light on my '92 (shoulda taken pics to post on here...they work great now!)
Question: Does the battery voltage drop if the car is left sitting for a while? If so, that will indicate a short somewhere. An ammeter tapped in place of the fuse can show the amount of drain (check to make sure your meter can handle the amps first!). Check with the key in all positions (OFF, ACC, ON, etc.) and also with doors closed, open, and pressing the sunroof open/close buttons. Changes on the meter readout will indicate power flow.
7.5A does sound low for run both dome light and sunroof, but who knows for sure? Check the wiring diagram.
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
