Does anyone know the location of the #6 Ignition Coil on the Mazda Tribute? I believe they are under the Plastic cover on the Engine but Now sure which one is #6..
Remove the front top cover and look on the wiring. They are numbered there. I believe 6 in on the side closet to the radiator and to the right. the other are accessible by removing the intake. That takes about 25 minutes to remove and 25 to put back on. The gaskets are o-rings so they do not have to be replace unless you do something that damages them.
