Couple problems with a 02 GPatherts01 12-10-2007, 10:46 AM I am helping my friend with his 2002 pontiac Grand Prix with the 3800 motor in it. The first problem I am having is that blower motor only works on high position. But when you put blower on high it turns the day time running light off. The thing that is not working is the head up display. Any ideas would be great. richtazz 12-10-2007, 11:17 AM You could be having one of several problems. The blower resistor is a common issue that causes the loss of low speeds. It is located in the heater box under the dash next to the blower motor itself. Another issue is water intrusion from a bad cowl seal under the hood on the passenger side. Water gets in the heater box and shorts out the resistor. If there is water, the resistor will still need to be changed, but this is a case of treating the disease (the water intrusion) rather than the symptom (shorted resistor). With your other issues (HUD and DRL's), you could be experiencing the first symptoms of a bad ignition harness assembly. The contacts start to arch and will cause many electrical gremlins to crop up. Here is a link to the replacement proceedure in the "tips and maintenance" sub-forum at the top of this forum. Here's the link: http://www.automotiveforums.com/vbulletin/showthread.php?t=653340 Finally, the HUD could be a bad solder point in the HUD circuit board. Here's a link to an old thread that deals with this issue. Follow the thread and click on the link. http://www.automotiveforums.com/vbulletin/showthread.php?t=669409&highlight=heads+up+display atherts01 12-10-2007, 11:25 AM You could be having one of several problems. The blower resistor is a common issue that causes the loss of low speeds. It is located in the heater box under the dash next to the blower motor itself. Another issue is water intrusion from a bad cowl seal under the hood on the passenger side. Water gets in the heater box and shorts out the resistor. If there is water, the resistor will still need to be changed, but this is a case of treating the disease (the water intrusion) rather than the symptom (shorted resistor). With your other issues (HUD and DRL's), you could be experiencing the first symptoms of a bad ignition harness assembly. The contacts start to arch and will cause many electrical gremlins to crop up. Finally, the HUD could be a bad solder point in the HUD circuit board, and there is a thread in the "tips and maintenance" sub-forum at the top of this forum. What does the resistor usally cost?? Can I get the ignition harness assembly and a local auto parts store or do I have to go to a dealer? richtazz 12-10-2007, 11:39 AM The resistor should be less than $25. The switch/harness is AC-Delco, and should be available without going to a dealer. I also edited my original post and included the links to the repair proceedures for the ignition switch and HUD for you. atherts01 12-10-2007, 11:53 AM Thank you I am going to do this tonight if I can get the parts. JonJon68 12-10-2007, 12:36 PM X2 on the A/C Delco part. I just changed mine out last month. I purchased the resister from rockauto.com for about 26.79, 31.00 shipped. I couldn't find a parts store with an A/C Delco blower resister in this area and the dealership wanted 60.00. atherts01 12-13-2007, 12:33 PM You could be having one of several problems. The blower resistor is a common issue that causes the loss of low speeds. It is located in the heater box under the dash next to the blower motor itself. Another issue is water intrusion from a bad cowl seal under the hood on the passenger side. Water gets in the heater box and shorts out the resistor. If there is water, the resistor will still need to be changed, but this is a case of treating the disease (the water intrusion) rather than the symptom (shorted resistor). With your other issues (HUD and DRL's), you could be experiencing the first symptoms of a bad ignition harness assembly. The contacts start to arch and will cause many electrical gremlins to crop up. Here is a link to the replacement proceedure in the "tips and maintenance" sub-forum at the top of this forum. Here's the link: http://www.automotiveforums.com/vbulletin/showthread.php?t=653340 Finally, the HUD could be a bad solder point in the HUD circuit board. Here's a link to an old thread that deals with this issue. Follow the thread and click on the link. http://www.automotiveforums.com/vbulletin/showthread.php?t=669409&highlight=heads+up+display Updates: I replaced the blower resister and that did not fix the problem. But I think it needed to be replaced anyway. Any Ideas?? The instuctions on getting ignition harness off worked great. Tonight I will be installing the new one. richtazz 12-13-2007, 12:54 PM Let us know if the ignition harness doesn't help, as that would be the next step to fix your issue. atherts01 12-14-2007, 07:47 AM Let us know if the ignition harness doesn't help, as that would be the next step to fix your issue. The ignition harness did the trick. Thank you for all your help. richtazz 12-14-2007, 11:51 AM The ignition harness did the trick. Thank you for all your help. Excellent, you're very welcome, and thank you for the feedback. We like to hear back when something works out, plus it might help someone later having the same issue if they read this thread and see what worked. :thumbsup: Automotive Network, Inc., Copyright ©2012
