Acura 1997 SLX 147,000 miles plusromya1206 12-08-2007, 01:03 PM I own an Acura SLX 1997 SUV 6 cyl. and whenever the engine starts the two side mirrors folds back and won't return to its original position if corrected. When I open any of the driver or passenger door those fold back parallel to the door. When manually as well as electronically corrected, those won't. What's the problem? What should be done to correct the problem? Thanks romya1206 12-08-2007, 01:08 PM I own an Acura 1997 SLX with 147 miles and whenever I start the engine the two side mirrors fold parallel to the doors. The driver side mirror could be corrected manually while the passenger side could not be. When I open the driver side door, the side mirror folds back while the passenger side always fold back to its original position parallel to the door or glass. What's the problem. I would appreciate any enabler helping me....What should be done? Lakeshow23 12-18-2007, 10:11 PM I own an Acura 1997 SLX with 147 miles and whenever I start the engine the two side mirrors fold parallel to the doors. The driver side mirror could be corrected manually while the passenger side could not be. When I open the driver side door, the side mirror folds back while the passenger side always fold back to its original position parallel to the door or glass. What's the problem. I would appreciate any enabler helping me....What should be done? I don't understand what you're trying to say. Basically, it sounds like your mirrors are malfunctioning. Try replacing the switch. Visit an Isuzu dealer for a new one. If it helps, check eBay and try to find the switch there. Search for "Isuzu Bighorn" if you have to, the switch is most likely exactly the same as the Troopers JDM variant. amigo-2k 12-18-2007, 11:33 PM You can unplug the switch to see if that helps. Automotive Network, Inc., Copyright ©2012
