99 gtp Annoying problem no heat/hvac!tiffany716 12-07-2007, 08:31 PM hey wats up AF im having an issue with my car that needs to be taken care of due to the cold ill try to explain best that i can! my car has some type of short or issue with the wiring for my heat and my hvac info display right above the heater (i have the one thats all digital, gtp supercharged model) and my ac/heater control (dual control digital). everything used to work all right with the exception of the hvac info being a little dim 1. my ac control started just flickering on and off, working from time to time but 95 % of the time it doesnt work. i bought a new ac control in case that was the problem but same thing. 2. when i unplug the heater control the hvac info isnt dim anymore and its accurate like it should be.. 3. now when i turn the heated seat switch on the hvac info dims all the way off and flickers off and on like the ac control lights do... 4. when the heated seats are on i hear little popping noises but the seat heats fine (the only heat i have) 5. the heater control will not turn on right no matter wat is pressed, but everything works stand-alone.. 6. where im at theres no shops that wanna do any electrical auto work and i know i could figure something out with a little help n advice... any advice is appreciated... (P.S.) Every fuse works i used a test light to check eve the ones under the hood BNaylor 12-08-2007, 09:47 PM Welcome to AF. Please be advised that we do not allow duplicate or redundant posts seeking help at more than one AF forum. I noticed you have a post at our Engineering/Technical forum in addition to this forum. Therefore, this thread has been closed pending whether you get any replies at Engineering/Technical. If you have any problems with this you may PM message me. BE COURTEOUS: AVOID DUPLICATE POSTS Do not post the same discussion more than once on a discussion forum or on many forums. Duplicate discussions can be frustrating for other members, especially for those whose time and energy is limited. Weeding through the same discussion in multiple locations can be not only frustrating, but down right annoying. Duplicate discussions will be deleted. Reposting the same message repeatedly can be interpreted as SPAM and could result in the loss of your membership. Also be conscious of your fellow members and avoid making meaningless posts for the sole purpose of increasing your post count. Automotive Network, Inc., Copyright ©2012
