99 Silverado "Service 4WD" actuator replacementmznkb3 12-06-2007, 01:39 PM MY Service 4WD light came on. Replaced the switch - no change. Had the dealer run a diagnostic. Possible T.C. speed sensor, possible module, possible transfer case clutch pack. Any suggestions? The module is $171 on GMpartsdirect.com. The dealer quoted $1800 for a new transfer case!!! HELP!!! mznkb3 12-06-2007, 01:41 PM The dealer also quoted $300 for the module statinf it needs to be programmed. Can I replace it?? Does it really need to be programmed? j cAT 12-06-2007, 03:26 PM MY Service 4WD light came on. Replaced the switch - no change. Had the dealer run a diagnostic. Possible T.C. speed sensor, possible module, possible transfer case clutch pack. Any suggestions? The module is $171 on GMpartsdirect.com. The dealer quoted $1800 for a new transfer case!!! HELP!!! does the 4x4 work? if it does ignore the light it. mznkb3 12-06-2007, 03:56 PM No the 4WD does not work. and I need it to work. j cAT 12-06-2007, 05:20 PM No the 4WD does not work. and I need it to work. On a vehicle that old replace transfer case total r/r.....Or buy another 4x4. If you are the original owner and replaced transfer case tracII fluid every 30,000mi I might consider taking the chance of changing componets. if you go this route I bet dealer will not warrantee this to work, more than a few months. must remove transfer case and inspect internals to determine if totally trashed................ Automotive Network, Inc., Copyright ©2012
