Re: Can a motor be locked up without noticing anything going bad?
When you turn on the ignition key to the 'start' position; it is normal for the accessories (radio, wipers, heater fan,etc) and the indicator lights on the instrument cluster to go out. However with the drivers door open, the dome light should probably stay on - even while the ignition key is in the 'start' position and even while the starter is cranking the engine.
I think a suddenly-bad starter is more likely than a suddenly-siezed engine. But...as a previous poster said; try turning the motor using a wrench on the crankshaft pulley - the one with the serpentine belt on it. With the plugs out it should turn okay. Have a look at the dipstick - see if there are any tiny shavings in the oil. That would indicate it had been run without enough oil. Finally, you can drain the oil from the motor; into a clear or glass container you can see into. Look up into the bottom of the container and see if there are tiny metal particles in it. If any - its bad news.
It could be a bad starter. I had to replace the starter in our 92, when it was taking several tries to get the car to start. It would just make a nice click each time, but eventually would start. The old starter had about 100,000 miles on it.
Check that the ground connections are in good shape (the negative side of the battery). If they are corroded, getting a jumpstart via the jumper cables connected to the battery posts wont help.
With late model cars with computers in them - I would never attempt to connect the jumpers anywhere other than the battery. This means those cables have to be in decent.
Every ground wire on your Escort is -important- to something the car does.
