is it the fuel pump?
Google
Web AF
cf1
12-05-2007, 08:42 PM
a 1992 3.8 fifth ave.. stoped runing, poured some gas in throttle run breifly.. let it sit over night started right up, ran for about 20 min. died.. where do i start checking thing? wheres the fuel filter> and fuel pump. any help thanks..
Mongoose_Fear93
01-15-2008, 09:39 PM
well i would start with the fuel pump which would be located in your fuel tank cause atleast if you had a partical plugged fuel filter you would still be getting fuel to the throttle body so check with that another way to check if your fuel pump is working is if you put key on do you hear a buzzing noise from the back end?
cf1
01-15-2008, 10:25 PM
i replaced the fuel pump and filter ther car run perfect,,thank you case closed..
Google
Web AF
