Re: ABS light only comes on over 100km
Do you have any noises, vibration, shimmy coming from the front end? Since your car's wheel speed sensor picks up it's signal from a reluctor on the axle shaft, anything that would cause excessive vibration in the front end (bad hub, out of balance tire, bad tie rod, etc...) could cause an ABS issue as speed increases.
Would you drive any better with that cell phone up your ...?!
