Re: '97 ALC Questions
Hello, and welcome to AF! You must have a hefty leak for the compressor to run all the time. Normally, the compressor will inflate until the car is level and then turn off. If you had a small leak, it may maintain ride height for several days before the compressor would come on. The ALC suspension has computer matched rear springs that depend on 12-15 psi being in the strut bladders to maintain ride height. Without the air assist, the rear will sag. The ALC struts only cost about 10-15 bucks more each than the standard struts. I think that after you install the new air assist struts, you will agree that was the best bang for the buck.
Knowledge can be communicated, but not wisdom! “Ye shall know the truth and the truth shall set you free."
