Leaking 95 Jimmy 4WAL ABS controller unit
agrafixx
12-03-2007, 03:01 PM
Hey all,
My ABS light has been on for a while and today I am leaking brake fluid from the ABS controll unit on the bottom around the seam. Can that gasket be replaced and if not can the ABS system be capped off to eliminate it?
Any help would be great
MT-2500
12-03-2007, 05:04 PM
If it has them it is a safty issue if you do any capping off.
If it is not a line leaking
Sounds like you will need another abs unit.
Take a close look at where it is leaking and check with your dealer for any seals in that area..
As far as it will have to be replaced as a unit.
Good Luck
MT
