95 - Fuse in steering columnstlbuick 12-03-2007, 10:54 AM I have a question about disconnecting the horn fuse in a 95 le sabre. How do I get into the steering column? Is it necessary to disconnect the battery? Any airbag concerns? Anything else? dugan50 12-03-2007, 12:42 PM The fuse for the horn is not in the steering column...what are you trying to do? stlbuick 12-03-2007, 12:53 PM I was going off of this: http://www.commandocaralarms.com/wiring/1995/Buick/LeSabre It's not? I'm trying to disconnect the horn because it will go off randomly, with no one inside the car. I think it's due to the weather. dugan50 12-03-2007, 12:57 PM Most likely it's going off because the contacts in the steering column are touching when they shouldn't be. If you want to remove the fuse, that will stop it. The fuses are located under the dash on both sides of the kickpanels, and I think there is a bank of large ones under the hood beneath the wiper blades. You don't need to go into the steering column, but if you do, you will need to remove th airbag and disable the system first. HotZ28 12-03-2007, 09:42 PM I was going off of this: http://www.commandocaralarms.com/wiring/1995/Buick/LeSabre If you look closely at the site you posted the link to, you will notice that the reference is to the “Wire Location” (not fuse) "Horn black Negative (-) steering column". :) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
