Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Xterra > How-to's & Installation
How-to's & Installation Share your techniques with other owners.
Old 12-01-2007, 08:31 PM   #1
bosi
bosi Normal reputation
Lightbulb front wheel 4W lock
Looks like my front wheel lock that engages the wheel into drive is broken. When I shift into 4H it makes quite a noise. Does anyone have any advice on fixing this (besides going to certified Nissan service)? I'm surfing i-net and can't find any info, even the name of the part that engages the wheel.
Please don't yell if this is a wrong section, I'm a newbie here
bosi is offline   Reply With Quote
Old 12-01-2007, 09:06 PM   #2
chubbybubba1
chubbybubba1 Normal reputation
Re: front wheel 4W lock
Are you shifting on the fly or at a stop?
chubbybubba1 is offline   Reply With Quote
Old 12-01-2007, 09:10 PM   #3
bosi
At a stop. Although they say you can shift below 30, I wouldn't do that, I have time. Just when I had my breaks done the guy told me that some sort of 3-peg clutch that engages the wheel has a peg broken.
Old 12-01-2007, 11:07 PM   #4
chubbybubba1
So at a stop, the the transmission in nuetral? Engine running or not running?
Old 12-02-2007, 09:53 AM   #5
OffroadX
OffroadX Normal reputation
Send a message via AIM to OffroadX
Note that noise in an automatic locking hub nearly always indicates a problem in the opposite hub. It's pretty simple to replace one, but they're $80+ each from a dealer. All you need is a hex wrench and a snap ring tool.
When did you last check your spare tire's pressure?
OffroadX is offline   Reply With Quote
Old 12-02-2007, 08:22 PM   #6
bosi
Thanks, sounds simple enough.
Old 12-03-2007, 11:34 PM   #7
bosi
Whow, so I called the dealer and he quoted me $250 CDN part and 1.5h labour - it ain't cheap up here in Canada. With taxes it would set me back over $400.-! Therefore I ordered Wran part from a local automotive shop, pair of hubs for $150.-. When I went to pick them up we realized that these are manual (inspite me telling the clerk several times that I am looking for the automatic locking hubs). Never min, I'll have to change them from the original automatic. I read somewhere here that manual hubs are actually considered an upgrade by enthusiasts. I am not sure about it. Is that true? Apparently they are more reliable and solid. I fear the moment when I take it apart and realize that I'll need some sort of special conversion kit or something like that....we'll see
Old 12-03-2007, 11:35 PM   #8
chubbybubba1
If your going to go through the hassle of replacing hubs, go with a set of Warn manual hubs. The stock ones are junk. They do the job but the guts are junk. Part #29091 plus #29061(gaskets).
Old 12-04-2007, 01:58 AM   #9
Schludwiller
XTerra Guy
Schludwiller's Avatar
Schludwiller Normal reputation
The reason people consider the manuals an upgrade is that they don't disingauge when you slip back down a hill. Once they're locked, they're locked. Auto hubs are designed to disingauge when you roll back (part of the unlocking feature described on your sun-visor). Great when you don't want to get out of your truck in the mud and snow, bad when you're stuck on the side of a hill and have to get moving forward in 2wd to lock the hubs up again.
With manual hubs, always engage them before you need them. Keeps your boots clean. ;-)
Xterra4x4.com and the Xterra Offroad Webring
Schludwiller is offline   Reply With Quote
Old 12-04-2007, 02:00 AM   #10
Schludwiller
XTerra Guy
With manual hubs, always engage them before you need them, but keep it in 2wd unless the situation warrants. Keeps your boots clean.
Bookmarks
Google
Web AF
