2004 GC, No Heat, Blower works, help?2004GC 12-01-2007, 03:08 PM The blower works fine, but the heat no longer works. I also noticed the temp gauge fluctuating between 1/2 way and 3/4 while driving. A week ago, the heat was intermittent. Any ideas? inafogg 12-01-2007, 03:14 PM hello has anything been done to the cooling system lately??is the radiator full??it sounds like possible air trapped in system.might want to try bleeding cooling system 2004GC 12-01-2007, 03:16 PM No work has been done, radiator is full. inafogg 12-01-2007, 03:19 PM how many miles on car?? 2004GC 12-01-2007, 03:22 PM 65k inafogg 12-01-2007, 03:42 PM hey GC i still would try to bleed system.i dont no if there is a bleeder on your car look on thermostat housing for one.but if nothing has been done service wise i dont see how it got air bound.does car overheat you said 1/2 - 3/4 on temp gauge. 2004GC 12-01-2007, 03:47 PM I just noticed today, while driving, the temp gauge was at 1/2 way and then moved to 3/4 way, and then dropped back to 1/2 way, all in about 30 seconds of driving. Once again no service has been done. Is there a bleeding valve for 2004s? And if so, how would you do that. Should I just change the thermostat w/ gasket? inafogg 12-01-2007, 04:14 PM i not sure if it has a bleeder but look around thermostat housing.if so with engine running open bleeder to release air/bubbles.(may take awhile)if coolant has'nt been change in awhile then i would change + thermostat.there's been talk about drilling 1/8 hole in top of thermostat if not already done to help with air 2004GC 12-01-2007, 09:34 PM I figure I will change the thermostat (never done it before). Can you tell me where it is located? I followed the upper hose the engine, but nothing looked obvious - in fact I thought some type of spark plug wire case was there - didn't look too long as it is getting real cold. Any help would be appreciated. Also, do you have to drain fluid to change it? wayneo69 12-01-2007, 10:24 PM it should be below the coil pack follow the upper rad hose 2004GC 12-02-2007, 08:59 AM Do I disconnect the upper rad hose to get to it, or do I take the coil pack off? Automotive Network, Inc., Copyright ©2012
