head gasket replacmentshultzie 11-29-2007, 10:05 PM I have a '98 dodge neon r/t with a DOHC it has good compression in cylinders one and two cylinder three has no compression at all and cylinder four has about 3/4 compression. we think it is the head gasket but not sure. how hard is it going to be to just replace the head gasket and is that what i should try first? Thanks. das2123 11-30-2007, 08:32 AM Low compression could be a bad headgasket or bent valves. It isn't very difficult to change the HG, but if you haven't done it before...it may take you about a day or 2. shultzie 11-30-2007, 03:32 PM even if its bent valves i still have to take off the heads, so its worth looking into versus just putting a new engine in right? Thanks agin das2123 11-30-2007, 03:35 PM Yes, you would have to take the head off. Automotive Network, Inc., Copyright ©2012
