Looking for firing order diagram 96 4.3l vin W
scholzee
11-29-2007, 07:06 AM
Is the firing order in figure 3 diagram incorrect ? They show #1 middle cylinder drivers side. Is drivers side considered bank one ?
http://www.autozone.com/az/cds/en_us/0900823d/80/18/b0/b9/0900823d8018b0b9/repairInfoPages.htm
MT-2500
11-29-2007, 09:41 AM
It is marked right on the cap.
But they reversed 1-3 on the engine.:grinyes:
All engines has lowest no cylinder at front of engine.
The 4.3 V6 and most GM engines no one is on front of engine left side drivers side.
Are you just needing the firing order or you setting the dist after being out.?
MT
herkyhawki
11-29-2007, 09:45 AM
Fig 3 in that link is not correct. #1 is front cyl on drivers side.
scholzee
11-29-2007, 01:31 PM
MT-2500 & Herkyhawki I appreciate your help. I am struggling with a misfire and used the link from this site to the autozone repair manual. I changed my plugs, cap, rotors,and wires with AC Delco a year ago and now have a flashing check engine light misfire. I changed plugs & wire 1 @ a time and it ran good 4 a year so I know I did it right, but when you get conflicting info you always ? your self. I am hoping I used too much dielectric grease and something is working loose. I will pull wires and plugs check compression and connections continuity of wires etc, but always like a true diagram in case I get lost.
old_master
11-29-2007, 08:23 PM
Typical Autozone, you get what you pay for. Good thing this information was free. The diagram is numbered WRONG on their engine. Driver side front to rear is 1 3 5. Pass side is 2 4 6. The distributor cap in their diagram is shown correctly.
