94 Blazer hard to start
GNRAxlRose88
11-28-2007, 02:07 PM
Hey all
I have a '94 S-10 Blazer with the vortec 4.3 litre V6. The motor has under 50,000 miles on it as it was replaced by the last owner who passed away.
I let the Blazer sit for awhile because i didn't need it at the time. When i went to start it, it didn't want to start, as i expected. I sprayed the air intake with starter fluid and it fired off...but now every time it sits, even overnight, i have to spray it to start it.
When it gets to operating temp. and i shut it off, it fires up like it was new.
What could be causing this? Any help would be appreciated.
Thanks
old_master
11-28-2007, 08:20 PM
....I sprayed the air intake with starter fluid and it fired off...
There's your clue, low fuel pressure. Fuel pressure must be a minimum of 60psi, cold engine, pump running, engine off. After the pump shuts off, pressure must remain above 55 psi for 3 to 5 minutes.
GNRAxlRose88
11-29-2007, 04:35 PM
so what could cause this? could it be a clog in the filter or is the pump going out? or...?
and for being a V6 it goes thru as much, if not more, fuel than my fullsize bronco with a 5.0
old_master
11-29-2007, 07:55 PM
We don't know what the problem is yet, so it's impossible to determine what caused the problem ;) The first step is to check fuel pressure and leakdown. If you need the entire procedure, PM me with your email address and I'll send it to you.
