Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Buick > LeSabre
Old 11-28-2007, 11:56 AM   #1
gutzguy
gutzguy Normal reputation
92 le sabre emission test fail NO ppm
well i took my car for emission test and it failed. the test said the no ppm limit is 408 my car is reading 1157ppm any ideas as to why reading is so high
gutzguy is offline   Reply With Quote
Old 11-28-2007, 02:45 PM   #2
maxwedge
A990 racer
maxwedge Normal reputation
Re: 92 le sabre emission test fail NO ppm
Welcome to AF, NOX, I assume is what you are referring to? Inop egr if equipped is number one, number 2 is a bad cat and very high engine temps is number 3.
maxwedge is offline   Reply With Quote
Old 11-28-2007, 09:14 PM   #3
HotZ28
AF Moderator Elite
HotZ28's Avatar
HotZ28 +50
Wink Re: 92 le sabre emission test fail NO ppm
WHAT IS NOx?
Nitrogen and oxygen naturally coexist in the atmosphere. At temperatures above 2500 degrees Fahrenheit (which occurs in the combustion chamber), they chemically combine to form NO, NO2, and NO3 – also known as NOx, which is a corrosive gas.
In addition to the items mentioned by Max, some other possible causes of excessive NOx include:
Incorrect ignition timing
Incorrect fuel pressure
Broken or leaky vacuum hose
Faulty mass air flow sensor
Faulty or malfunctioning thermostat
Old coolant / antifreeze
Faulty oxygen sensor(s)
“Ye shall know the truth and the truth shall set you free."
HotZ28 is offline   Reply With Quote
Old 11-28-2007, 11:33 PM   #4
gutzguy
thanks for your help i will try the EGR first maybe just a ceaning will help
Old 12-01-2007, 04:31 AM   #5
spinne1
spinne1 Normal reputation
Well, it is an urban legend (I don't know if it is true or not!) to take your car on the interstate right before emissions testing and really ride it hard for about 10 miles or so (go about 80-90 mph if you can get away with it) and "blow out" the cat. I always do it because my two LeSabres are old. However, after recently rebuilding my two engines in the past year my testing has gone extremely well. After testing my wife's car with 197K (but newly rebuilt engine) the testing guys seemed surprised at how low my numbers were because of my mileage. One number was like 14 ppm with a max allowed of 220 and the other was 0. The other car had similar numbers but lower.
spinne1 is offline   Reply With Quote
Bookmarks
Google
Web AF
