83 4wd 22r / camber problems
clawbar
11-26-2007, 11:51 PM
I have recently encountered camber problems, resulting in excessive wear on the inside of the tire. According to the Chiltons manual, camber problems on a 83 4wd pickup, are fixed by replacing the bushings. After replacing the bushings, it still has camber problems. any ideas how to fix this ???
fourwd1
11-28-2007, 10:57 AM
Which bushing did you replace,the brass ones inside the axle?
A bent axle housing could also lead to camber problems.
clawbar
11-28-2007, 03:51 PM
I replaced the leafspring bushings, and torsion bar bushings. I was unaware of the brass bushings.I will look into that. thank-you.
fourwd1
11-29-2007, 08:55 AM
Worn leaf spring and t-bar bushings would affect handling, not camber.
The brass bushings are the only one's I can think of that could possibly have some effect on it.
§©RÉWßã£
12-01-2007, 08:19 PM
Its most likely your trunion bearings, or loose steering arms. the steering arms are used to set the preload on the trunion bearings inside the knuckle.
its the bearings on the top right
http://www.marlincrawler.com/images/knucklekit_500.jpg
can be bought here (http://www.marlincrawler.com/htm/axles.htm)
