spring rates
GreyGoose006
11-26-2007, 03:26 PM
does anyone know the stock spring rates for an 85 camaro IROC-Z?
i am looking at getting new springs, but would like to know the original rates for comparisons
GreyGoose006
11-28-2007, 07:12 PM
anyone?
GreyGoose006
02-06-2008, 06:25 PM
one last time?
anybody?
cuda_dude
02-06-2008, 09:28 PM
I've looked high and low with no luck.. sorry man
GreyGoose006
02-11-2008, 01:50 AM
how in the world would i figure it out.
only thing i can think of is taking the springs out one by one and putting 150 lbs on each spring, measuring its deflection, then calculating its spring rate.
cuda_dude
02-11-2008, 01:58 AM
I think your best bet would be to call hotchkis or another spring manufacturer.
72chevelleOhio
02-11-2008, 02:22 AM
Are you thinking of getting drag race only springs? Most "sport" springs I found are just big block or small block specific.
GreyGoose006
02-16-2008, 08:58 PM
i was going to have a set of springs custom wound for a slightly lower and stiffer feel.
72chevelleOhio
02-17-2008, 12:12 AM
i was going to have a set of springs custom wound for a slightly lower and stiffer feel. Custom as in someone/company you know make them for you? or custom as in company made specifically for the 82-92 body? Just curious. I found several springs, the only options as far as spring rates are for the drag race only springs. The street/performance springs only differ by big or small block. Lowered springs, I would think, should be stiffer anyway, you would have less suspension travel (room) to work with and would "bottom out" quicker if they were the same rate...
GreyGoose006
02-17-2008, 02:42 PM
theres a company that, if you tell them the original rate and length you can specify your percent over stock stiffness and drop.
i would tell them something like 30% increase in stiffness and 1.5" drop and get a set of four springs in the mail
http://www.coilsprings.com/
72chevelleOhio
02-17-2008, 05:51 PM
the website was down when I tried it. Are they going to be cheaper then jegs or summit racing? I just seen a set at jegs for $273.99 (hotchkis) unless your trying to go lower than 1 1/2"....If you find they are cheaper please post it. I'm thinking of using my income tax return on a suspension for my velle.
GreyGoose006
02-23-2008, 01:35 PM
i dont know about cheaper, but i have a feeling that the stock rates are well balanced in terms of spring rates and body frequency for optimum handling.
if an aftermarket company doesnt do their research and simply makes them stiffer and lower, without balancing the cars springs, then the handling will be off.
this way, i can say,
the rear spring rate is this... make it 25% stiffer.
the front spring rate is this.. make it 22% stiffer.
make the front 1 inch lower.
make the back 1/2 inch lower.
its just more customizable IMO.
but in order to do any of that, i need the stock rates, and i cant find them anywhere
blindeyed
02-23-2008, 11:45 PM
Maybe this might be able to help you out.. I dug and dug and dug and this is all I could really find.
http://www.federalmogul.com/en/After...s/Catalogs.htm (http://www.federalmogul.com/en/AftermarketSolutions/NorthAmerica/TechnicianResources/Catalogs/Catalogs.htm)
1) Select make/model lookup
2) In the window that opens select your vehicles information.
3) Click "steering solutions"
4) Click "front springs" or "rear springs" to look up info.
Once the list appears, clikck the https://mfr.activant.com/mfrserv/images/c2c.gif to display spring info. These are OEM reproduction springs that have been based off of the OEM specs.
Hope this helps ya man.
GreyGoose006
02-24-2008, 10:04 PM
you are a GOD!!!
would it be weird if i said i love you?
:greddy2:
how bout i call no homo first...
:wink:
thanks a LOT
