Which is better?lilsweets3138 11-26-2007, 03:09 AM Which is better? 2 12'Sony Xplod Subwoofers 1200watts,350 watts continuous rms 2 12'Rockford Fosgate Punch P2 subwoofers 50-250watts rms (500 watts peak) And can the fosgates be powered by a sony xplod 1000 watt amp 2 ch? jakegday 11-26-2007, 08:16 AM the rockfords, without a doubt you wouldnt buy car audio equipment at a department store would you? lilsweets3138 11-26-2007, 06:00 PM the rockfords, without a doubt you wouldnt buy car audio equipment at a department store would you? Okay, how many RMS total will I be able to get using my 1000 watt amp?? example 2 fosgates P1S410 Power Handling: Peak: 300 watts RMS: 150 watts Impedance: 4 ohms Or can my amp power more then that? And thanks again. Mangoamerican 11-26-2007, 07:02 PM sony amps will give you about half of what you think they will.. for 2 seconds JStumpalump150 11-26-2007, 07:08 PM basic rule of thumb, if its in walmart it should not be in your car. end of story lilsweets3138 11-26-2007, 07:21 PM I just need to know how many RMS my amp can handle. I really don't understand on how matching your amp and subs work. But If you guys can give me somekind of info on it then I will know what I can work with. I am planning on getting Rockfords but not sure on the watts and rms. This is what I want to get: 10" Single 4 ohms Punch Stage 4 Subwoofer Power Handling: Peak: 300 watts RMS: 150 watts Impedance: 4 ohms High modules closed conical polypropylene cone and ABS/Acrylic dustcap assembly geometry Tear and Fatigue resistant poly-cotton spider High density compressed half-roll sealed poly-foam surround High temperature voice coil with spun-laced Nomex insulating re-inforcment collar Optimized motor magnetics with extended pole and bumped backplate Multi-point high temperature/high strength neck joint bonding technique Semi-flexible PVC removable protective motor cover Custom insulated/isolated compression input terminal assembly Proprietary spider venting/cooling technique Frequency Response: 30 Hz - 250 Hz Sensitivity: 85 dB Free-air-Resonance: 30 Hz Mounting depth: 5-1/8" 1-1/2" 6-layer Voice Coil OR Rockford Fosgate P310D4 10" 800 Watts Peak Subwoofer 400 Watts RMS 800 Watts Peak 77 oz. Magnet Parabolic Injection Molded Polypropylene Cone Aluminum 2.5" Dual 4 Ohm Voice Coils Sensitivity: 85 db Xmax: 12.0 Qts: .564 Vas: 26 Fs: 28 5.9" Woofer Depth 9.22" Woofer Cutout 107.14 cu in. Displacement Sealed Box: 0.65 cu ft Ported Box: 1 cu ft - F3(Hz) - 35 OR Size 10"Impedance4-Ohm x 2Power Handling250 RMS 500 MaxSensitivity84 dBMotor Size60 oz. double stackedVoice Coil Diameter 2" aluminumSpeaker ConnectorDual 8 AWG compressionMounting Depth5.6875"Rec. Sealed Enclosure0.65 cu. ft. 18.4 litersRec. Vented Enclosure1.25 cu. ft. (35.4 liters) Tuning Frequency (vented)40 Hz millrtime 11-26-2007, 08:13 PM I just need to know how many RMS my amp can handle. I really don't understand on how matching your amp and subs work. But If you guys can give me somekind of info on it then I will know what I can work with. I am planning on getting Rockfords but not sure on the watts and rms.[/FONT] alright....its not about how many watts rms ur amp can "handle" its about how many watts it can put out. RMS is the continuous wattage amps put out at a certain amperage i.e. 12v, 14v......but a car only puts out 12v. as long as your sub can handle as many watts rms as your amp can put out, then you should be fine. its probably better to get a sub that can handle a little more than your amp is capable of. now you say you have a 1000 watt amp. is that max power? what voltage is that measurement taken? there is no magic "formula" to calulate anything like that. all that information should be included with your amp/sub. and if they arent, do some research and find out. these are things you need to know in order to see what your amp is truly capable of and thus, which subwoofer is the best match with it. hope this clears some stuff up. lilsweets3138 11-26-2007, 10:03 PM Heres what I found: Audio System Max Output Power / Channel Qty: 380 Watts x 2 Crossover: Active crossover Additional Features: Input level controls Response Bandwidth: 5 - 80000 Hz Signal-To-Noise Ratio: 93 dBA Continuous Power / Channel Qty: 165 Watts x 2 Amplifier Output: 2-channel High Level Inputs: Yes Input Signal Voltage: 0.3 - 6V, 1.2 - 12V Crossover Slope: 18 dB/octave Low Pass Frequencies: 80 Hz Output Power / Total: 1000 Watt Distortion Factor: 0.008% Amplifier Output Details: 165 Watt - 4 Ohm - 20 - 20000 Hz - THD 0.04% - 14.4V DC - 2 channel(s) ¦ 200 Watt - 2 Ohm - 20 - 20000 Hz - THD 0.1% - 14.4V DC - 2 channel(s) ¦ 400 Watt - 4 Ohm - 20 - 20000 Hz - THD 0.1% - 14.4V DC - 1 channel(s) With this said, does this mean I can get two Rockford subs that are 150 RMS and 300 watts? Or should I get something higher? I don't mean to sound dumb, I just don't have no one else to ask. millrtime 11-27-2007, 05:23 PM Continuous Power / Channel Qty: 165 Watts x 2 Amplifier Output Details: 165 Watt - 4 Ohm - 20 - 20000 Hz - THD 0.04% - 14.4V DC - 2 channel(s) ¦ 200 Watt - 2 Ohm - 20 - 20000 Hz - THD 0.1% - 14.4V DC - 2 channel(s) ¦ 400 Watt - 4 Ohm - 20 - 20000 Hz - THD 0.1% - 14.4V DC - 1 channel(s) With this said, does this mean I can get two Rockford subs that are 150 RMS and 300 watts? Or should I get something higher? I don't mean to sound dumb, I just don't have no one else to ask. those are the only 2 things that really matter in all that. so its a "1000" watt 2 channel amp, but really it only puts out 330 watts at 14.4 volts, which a car is incapable of putting out constantly. all of the outputs listed are at 14.4 volts, so they are almost useless. u need to find the power output at 12 volts. now that is a pretty weak amp, it probably wont put out enough power to get the sound u want. if you are set on that particular amp, i would bridge the two channels together and get a 10" or 12" sub that can handle more power. like i said before, its always better for the sub to be able to handle more than the amp can put out, that way the chances of you blowing it are reduced. the amp and subs you mentioned would do alright, but 165 watts (it will be less at 12v) to each sub is not alot, but you may not want it to shake apart your car like i would want it to do. its all about how loud u want to go. the more power the better (in most cases), but with that power comes capacitor(s) and all that jazz. its better to ask questions now before you do it, than to do it and figure out you did it wrong. lilsweets3138 11-27-2007, 07:03 PM Thanks millrtime for your help. I really appreciate it. :) lilsweets3138 12-03-2007, 01:31 AM Another question, whats the diffrence between a 10" RF and 12" RF? jakegday 12-03-2007, 08:15 AM about 2 inches Schister66 12-03-2007, 09:18 AM Just my .02....spend the extra money and get a set of either Infinity or CDT. Rockfords arent very good and Sony XPlods are straight up garbage. jakegday 12-03-2007, 03:57 PM and Sony XPlods are straight up garbage. i second that, amps and speakers, i know this from experience, im not just some random shit talking asshole, there 1000 things that you just shouldnt buy at a department store, car audio is one of those things Automotive Network, Inc., Copyright ©2012
