Just got a wrecked 97 GSRAlex37211 11-25-2007, 11:12 PM It was hit in the back. I'm planning to do a complete motor swap into my EG. Are there any good sites out there with good step by step walk throughs for me? Also, any advice for a first time swapper? I know I'm getting into a big project, but it's basically all nuts and bolts right? Is there anything I should be extra careful of? Like, any delicate parts? Thanks for all your advice. I will most likely be refering back here if I run into any major obstacles. Christ 01-08-2008, 02:26 AM the search function works well, young obi-wan. B-series swaps are pretty straightforward, you need a mount kit,shift linkage, hybrid axles (I believe), the engine wiring harness, and a harness conversion from OBD-2 engine-side to OBD-1 ECU side. one way to get around the conversion harness is to change the plugs on your stock wiring harness, since it should be pretty close to the same wiring... just make sure that you don't try to wire in sensors that the ECU can't recognize. Hasport has just about everything you'll need to do the swap. Automotive Network, Inc., Copyright ©2012
