Re: Check Engine Light No Codes
In that case you might be on the right track about the radio install. There is a two wire data-bus plug (white and purple wires) that plugs into the back of the stock radio, I would check those out to make sure that no one wired anything to them.
Originally Posted by spenser
yes just a 12 and 50. After he pulled battery light still on.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
