99 Deville Motor Swap Help
96DEVILLE
11-22-2007, 02:22 AM
I Have A 99 Deville Concours Which Needs A Motor .can I Use A Motor From A Seville Or Eldorado.. I Know That A Deville Motor Won T Go Into A Concours.. The Deville Has The Letter (y) In The Vin .someone Told Me I Can T Use That Motor In A Con. Does Any One Know For Sure...... Thanks For The Help....
caddydaddy
11-28-2007, 07:59 PM
You will need to replace your engine with a L37 or VIN 9 engine. And it must be from a 1996-1999 car. So your choices are an ETC, STS or Deville Concours from those years.
What is wrong with the current engine?
96DEVILLE
11-29-2007, 02:56 PM
my car runs hot. i changed water pump,hoses, belt, cooling fan turn on and seem strong. then when i turn car off it over flows...this car has a temp. gage the needle goes from norm. to just before the red then goes back to norm..bafore this problem needle stayed at norm. and never moved...
thanks for help
caddydaddy
11-29-2007, 04:46 PM
Have you checked for a blown headgasket? NAPA sells a coolant test kit that checks for hydrocarbons in the cooling system. It's around $50. If it is a blown head gasket, have you considered fixing it, instead of replacing the engine?
Also, GM now sells rebuilt Northstars.
DFBonnett
12-01-2007, 09:31 AM
Have you ever replaced the thermostat?
96DEVILLE
12-01-2007, 12:58 PM
Also, GM now sells rebuilt Northstars.YES BUT I WAS TOLD THAT YOU CAN T FIX HEADGASKETS ON NORTHSTAIR... BECAUSE OF HEAD BOLTS :runaround: THERE S NO WATER IN OIL OR WHITE SMOKE NO SIGN OF ANTI FREEZE ON SPARK PLUGS....
96DEVILLE
12-01-2007, 12:59 PM
Have you ever replaced the thermostat?YES TWICE
maxwedge
12-04-2007, 07:40 PM
This does not belong in the open forums, I am moving this to the parts/cars, sale exchange.
