New Headlights Not Working On '99 AleroMlbluesboy 11-19-2007, 08:41 PM I got into a car accident a couple months ago. I could finally afford to purchase replacement headlamps for my 1999 Alero, and when I installed them I realized the power connector from the car and the headlights did not match up. My car has a connector with two wires in it, and my lights have a connector with 4 wires in it. I then went to my local auto wrecking yard and pulled off a couple connectors off of some other aleros to match my headlights (since I can't refund my headlights). When I hook them up, the lamps aren't working. How exactly do I connect the wires from my car to the new connectors, and if I have them wired correctly already, what can I do to make my lights work? I know the bulbs are good because I hooked the whole headlight up to a battery and it turned on just fine, and I have checked the fuses that I know of (inside my door, under my hood on driver side) and they don't seem to be blown... Please help me if you know what's wrong. xeroinfinity 11-19-2007, 11:45 PM Sounds like you have the headlamps hooked up wrong. You might have hooked it to the parking lamp wires which is two. Check this wire diagram for your headlamps. 99-01 Wire Diagrams-Exterior-Headlight-Interior lighting(instrument ICP illumination) (http://www.automotiveforums.com/vbulletin/showthread.php?t=758919) and welcome to AF. Automotive Network, Inc., Copyright ©2012
