turn signalsjpzcd 11-15-2007, 04:48 AM Am installing a vfiber cyber bodykit on a 93 camry. The turn signal cutouts on the front bumber are approx. 2 and 1/4 inch high and 11 inch long. Turn signal lights on car currently are approx. 2 x 9.5 inch. Anyone know of any make, model, year of a car or truck that have the turn signal light dimensions that I need (2 x 11 inch)? If needed I can use current ones and do more glass and body work, already had to do a shit load to get the front bumber to fit right. Thanks. 00accord44 11-17-2007, 12:32 PM The lower turn signals changed midway through that generation of Camry. Look at the 93 vs the 95 below. The panel on the 93 wraps around the corner. The 95 is much shorter and stops at the corner. Seems like you probably have the wrong year kt vs car. THe shape of the headlights is lightly different also, which I imagine was also part of the trouble getting this kit to fit your car properly. 93 http://www.fatihiauto.com/Image/Voiture_En_Vedette/Camry_93.JPG 95 http://www.ohiexchange.com/autos/vehicle%20images/95_toyota_camry.jpg Oops I Sharted 11-27-2007, 07:22 PM A better question is why are you installing a body kit on a camry.. craig34 03-21-2008, 07:22 PM 00accord44 has a valid point. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
