Re: Ingition switch
It could be your switch. Or your Pass-Key system, or a faulty wire, or your neutral position switch, or your starter, or your battery connection. The ignition switch would be the last thing I would suspect. Yet, it could go bad.
Check the most obvious first: battery and connection. Then, check your starter. Then, the neutral position switch, then the wiring, then the Pass-Kay, then the ignition switch.
