Brake Lights Dont Turn Off!!
ftd723
12-03-2002, 02:42 PM
I HAVE A 1994 TOYOTA TERCEL .FOR SOME STRANGE REASON ALL OF A SUDDEN MY BRAKE LIGHTS DO NOT TURN OFF EVEN WHEN CAR IS TURNED OFF. I CHANGED THE BRAKE LIGHT SWITCH BUT PROBLEM STILL THERE.
CAN ANYONE GIVE ME ANY IDEAS BEFORE I TAKE IT TO A MECHANIC.
THANK YOU
JWatson
12-06-2002, 02:36 AM
Check the little rubber bumper that the switch pushes on...it's
probably worn away causing the lights to stay on.
jwatson@toyotaworld.com
WHY ARE YOU YELLING?:(
magicmanjk808
12-10-2002, 04:45 AM
yep, that's it. same thing happened to me. it's gotta be the rubber piece. :D
ftd723
12-14-2002, 01:52 PM
Thank You!!I fixed the problem It was Definatley the rubber Bumper that was Worn Out.Its Weird I had 2 other Toyotas and this never happened Usually is the Brake Switch. Either Way Thank You Very Much.Problem Solved
supramk3
02-04-2003, 05:38 PM
I am having the same problem on my 87 supra, and I dont know what to do. The rear and brake lights dont shut off, no matter what I do. Please tell me what to do to fix it. I understand the problem was Identified, but I dont understand what you are talking about. It would help greatly if you told me how to fix this problem quickly beofre the battery burns out.
Thanks Much,
Greg
magicmanjk808
02-12-2003, 09:49 PM
on your brake pedal, toward the top, the should be a rubber stopper there. it sounds like yours broke or wore out, so go buy one from a parts shop like napa or something and just put the replace the stopper. if you need help, just ask the guys/girls working there. it's not hard to fix.
Skrip
08-22-2005, 01:09 AM
i used a simpler solution than going to the store. go to your garage/tool area. get a simple plastic device made for screws (the one that fills a hole in brick/cement). sorry i don't know the actual name for it. it worked perfectly for me. that IS a pretty scary problem when you first encounter it. hope this helps.
