Need help removing cam gear from 92 V6BowtieS10 11-11-2007, 09:32 PM I have a 92 pickup with a V6. In the manual, they mention a special tool you need to remove the cam gear. Is there any way you can remove the cam gear without the special tool? If not, what is the special tool?:screwy: :banghead: vin brown 11-27-2007, 12:38 PM I have a 92 pickup with a V6. In the manual, they mention a special tool you need to remove the cam gear. Is there any way you can remove the cam gear without the special tool? If not, what is the special tool?:screwy: :banghead: the cam gear uses 17 srew in the middle remove it then u can remove cam gear:) ering132 05-11-2009, 05:26 PM Had the same problem man! I really recomend going and buying a chain wrench!!! We struggled with that bolt for days hahaha. Hold the cam gear with the chain wrench and break it with a torque wrench. Save your nuckles and tools! We destroyed 5 tools before we got the chain wrench and popped it right off. Automotive Network, Inc., Copyright ©2012
