95 dies about half throttleJayrod0019 11-09-2007, 09:48 AM I have 95 2.2L. I have changed plugs and fuel filter. When it gets about half throttle in any gear it dies out. After a second or two you can give it gas, but no more than half throttle. Any suggestions..... 16th hippy 11-09-2007, 10:51 AM not the best thing to try, but what about going full throttle? is this dying issue only at half throttle, or there and anything past it? old_master 11-11-2007, 02:47 PM Have you checked the fuel pressure? If so what is it? What does the pressure drop to and hold after the pump shuts off? inafogg 11-11-2007, 03:51 PM i've seen where the tps goes bad at certain throttle positions. not sure if this is your problem but because 1/2 throttle is were it is most of the time.(50 - 60 mph) switch gets worn out in that position & messes with the signal to ecm vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
