Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > GMC > Sonoma/S-15
Old 11-08-2007, 10:45 PM   #1
tribble
tribble's Avatar
tribble Normal reputation
98 Sonoma start up problem
My 4 cylinder 98 Sonoma has been hesitating for a few seconds when I turn the key and then it starts and runs fine. I thought it might be the battery so I had that replaced but that wasn't it. It doesn't happen all the time, usually when it's cold or raining. I am a girl who doesn't know much about truck repairs so I would appreciate any help.
Live long and prosper
tribble is offline   Reply With Quote
Old 11-08-2007, 10:51 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Re: 98 Sonoma start up problem
Not sure if I understand... does the starter hesitate when you turn the key, or the starter cranks a bit before the engine runs?
old_master is offline   Reply With Quote
Old 11-08-2007, 10:57 PM   #3
tribble
tribble's Avatar
It turns over but it hesitates before it fires up. It sort of makes the sound like when you have a dead battery but only for a second or two. Not that tick tick tick of a dead battery but the sluggish turnover. Does that make sense?
Old 11-08-2007, 11:05 PM   #4
old_master
Advisor/Moderator
old_master's Avatar
Yes, that makes sense! When the battery was replaced, they probably cleaned the connections at the battery however, you might want to check the battery cable connection at the starter, and the ground cable connection where it's bolted to the engine. They need to be shiney clean and tight. A wire brush or file works well for cleaning.
Old 11-08-2007, 11:08 PM   #5
tribble
tribble's Avatar
Thank you OM, I will try that tomorrow and let you know if it helped!
Old 11-09-2007, 08:58 AM   #6
tribble
tribble's Avatar
Thank you, Thank you OM! That seems to do the trick, it is raining this morning and it started up fine after I cleaned up the doohickeys!
I hope you have a great day!
Old 11-09-2007, 08:15 PM   #7
old_master
Advisor/Moderator
old_master's Avatar
Doohickeys??? Too funny, I know what you're talking about though. Did you remove the bolts and clean the eyelet connectors?
Old 11-09-2007, 09:56 PM   #8
tribble
tribble's Avatar
I can't say as I removed any bolts but everything else is gleaming!
Old 11-09-2007, 10:35 PM   #9
old_master
Advisor/Moderator
old_master's Avatar
If you have any more trouble, it might be a good idea to remove the battery negative cable from the battery, (to avoid any sparks), then take the connections apart and shine 'em up with a wire brush or a file.
Bookmarks
Google
Web AF
