ABS light on 2004 F150
Kelhasfun
11-08-2007, 12:27 AM
Can you blank out an ABS light by disconnecting the battery or must it be cleared by a scanner?
frank41
11-11-2007, 06:17 PM
No. As long as there exists a legitimate mechanical problem that ABS light will stay on regardless until you fix the problem. A scanner will get you pointed in the right direction and after repair you can clear any fault codes. I feel your pain. I replaced both front hubs and the right front has a defective ABS sensor, which means I get the joy of tearing that apart again.
