Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Buick > LeSabre
Old 11-07-2007, 01:46 PM   #1
fsufan
fsufan Normal reputation
2000 Has strong gas smell with fill-up
My 2000 LeSabre has started to have a very stong gas smell inside the car when I fill up the tank.
It is extremely strong from the trunk area as well.
After I get below 3/4, the smell goes away.
Any ideas?
Thanks
fsufan is offline   Reply With Quote
Old 11-07-2007, 08:42 PM   #2
MikeS21
MikeS21 Normal reputation
Re: 2000 Has strong gas smell with fill-up
My 95 LeSabre had a similar problem. The way my mechanic explained it to me was that there was a fuel line coming out of the gas tank that had a clamp come loose. He tightened it back up and the smell went away.
MikeS21 is offline   Reply With Quote
Old 11-08-2007, 07:59 AM   #3
polarzak
polarzak Normal reputation
You can remove the access plate in the trunk and look at the fuel pump assembly (and hoses) where it goes into the tank. Fill your tank, and have a look for leaks. You might also look at the filler tube going into the tank for leaks, but you will need to get under the car to see this.
polarzak is offline   Reply With Quote
Old 11-10-2007, 07:25 AM   #4
Smith1000
Smith1000 Normal reputation
I had a strong gas smell from a 97 Lesabre. It was leaking gas from the where the fuel line meets the metal fuel line that goes into the tank. I ended up putting in a section of high pressure fuel line from the tank to the fuel filter with 2 clamps on each end.
I don't recall the gas smell going away when the tank reached less than 3/4 though. I would look around the fill tube (as mentioned) and the vent tube for the tank to see if it is leaking out there, like where the rubber tubes meet the tank. The clamps may be loose or there might be some other leak going on problem.
Smith1000 is offline   Reply With Quote
Bookmarks
Google
Web AF
