Cruise Controlmikl730 11-06-2007, 09:35 AM Hi in my 1994 buick lesaber custom my cruise control work once a month. When it does it is perfect and work woundefully untill the car sits for a day. Then It will not work for awhile again. When it works it sounds like there is a click under the glove box. Does anyone know if i have a malfuctioning relay some where. Thanks Mike HotZ28 11-06-2007, 10:29 PM Well, I just had to replace the ECU on my 94 to get the cruise working again. I don't know of any CC relay. happydog500 11-07-2007, 11:33 AM Well, I just had to replace the ECU on my 94 to get the cruise working again.Thanks for your input. My cruse doesn't work on my 97 ("Cruse" Light comes on, on the dash). I read about the ECU and never thought it would control the cruse. How did you figure out it was the ECU? I hate buying stuff that doesn't fix it. Thanks. "An engine control unit (ECU) is an electronic control unit which controls various aspects of an internal combustion engine's operation. The simplest ECUs control only the quantity of fuel injected into each cylinder each engine cycle. More advanced ECUs found on most modern cars also control the ignition timing, variable valve timing (VVT), the level of boost maintained by the turbocharger (in turbocharged cars), and control other peripherals. ECUs determine the quantity of fuel, ignition timing and other parameters by monitoring the engine through sensors. These can include, MAP sensor, throttle position sensor, air temperature sensor, oxygen sensor and many others. Before ECUs most engine parameters were fixed. The quantity of fuel per cylinder per engine cycle was determined by a carburetor or injector pump." mikl730 11-07-2007, 06:59 PM My light comes on too but shuts off when the speed drops below what it was set. Then once a month it will work perfect. There was 2 codes set in the computer i dont know if this helps. happydog500 11-07-2007, 08:49 PM What codes are set? mikl730 11-07-2007, 10:07 PM ill stop at the mechanic sometime next week but on his scanner it just had cruise contol listed next to them, because i had to get a new oxegen sensor put in and he reset the computer for me so i could pass inspection. They seem to go back on when ever the cruise control doesnt work but the check engine light dosent go on. Not sure why but ill try to get the numbers. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
