11-06-2007, 02:09 AM
HELP ME! Whats this Car engine part called?
Hey, I'm useless with cars. But I have a quick question about a part of the engine which sticks out of the hood. It has like 3 circles and flaps over the circles and it is usually found on muscle cars. I really want to know what this is called, and what it does.
Regards
Tristan
11-06-2007, 08:19 AM
Re: HELP ME! Whats this Car engine part called?
Hey there! If you would like a simple guide for identifying certain car parts order a Summit Raceing or J.C. Whitney catalog, you can get them on-line
11-06-2007, 10:40 AM
I forget what it's called but it sucks in air which gives the car a bit more power. I'll see if I can find out what it is.
11-06-2007, 01:50 PM
Its a blower.
11-06-2007, 09:38 PM
This is what you're talking about
This is the exact same thing, just different style.
It's kind of like a Ram Air setup. As you drive it sort of makes sure that air is fed straight to the air cleaners/filters which then goes to your carburator, and then goes to your supercharger. They are typically used on superchargers but I've seen them just used on high rise intakes as well.
'01 S-10 Xtreme - Supercharged 4.3L V6, 10 psi.
'88 Firebird Trans Am GTA - 5.7L V8, 4spd auto.
'06 GTO Brazen Orange Metallic - 6.0L V8, 6spd (the new toy/daily driver)
11-06-2007, 09:49 PM
It's called a Street Scoop or Carburetor Scoop you can go to this site http://store.summitracing.com/egnsea...11494&D=311494.
It is mostly for dressup but it does allow more air in the motor for more power.
11-07-2007, 02:15 PM
AF -Advisor
In the vernacular, it's called a "hat" by most racers today. It is the place the air goes, either into the blower as has been said, OR, just to direct the air into a carb or two (usually won't have the butterfly valves if there are carbs, but mechanical fuel injectors use them with the butterflys). We see them a lot on 2x4-bbl. systems, as well.
Technically speaking, it's the throttle body.
Jim
11-20-2007, 10:12 AM
Originally Posted by kkk
Useful reference.
The inexpensive "true" supercharger +its performance data are described. Please, visit insert favorite spam site
Spamalicious.
post edited for link.- wrightz28
11-20-2007, 10:22 AM
Backstabbing AF Moderator
got em
11-24-2007, 09:18 PM
at least he got it in mostly the right forum
1987 Mercedes Benz 190D turbodiesel
-5 speed transmission swap
01-14-2008, 11:31 AM
Sounds like it's been mostly answered and my bet is you've mainly seen the Mr Gasket knock off which fits everything down to a single 2 bbl carb. LOL.
It was made to look like the original injection setups from years ago where the 3 "round things" were the actual butterflys for the throttle back then as the regulated the air flow.
What you mostly see now if just basically a glorified air cleaner. As for the "Ram induction", sure okay, but almost all air filter setups have some sort of "scoop" somewhere.
Most street setups are more for looks than any real gains. Not that they don't work, just that you could even turn them backwards and they'd still do the job.
Den.
(Want safer drivers? Ban cellphones, GPS/NAV, traction/stability Control, backup cams/beepers/parking sensors and radar cruise. That'd be a good start! If you're that bad a driver-WALK!! PLEASE WALK!!)
02-09-2008, 11:28 PM
are you thinking of a carbeurator?
