Weird gas guageGodofwarmike 11-05-2007, 09:18 PM ok so my 96 SOHC neon is slowly getting its problems fixed. last night replaced the exhaust gasket flange to get rid of the weird sound when accerating (such an improvement :D). now it think its time to figure out the gas gauge. ok so whenever i get gas (fill her up) it goes to full. then about 20 miles down the road it drops to 1/4 tank or empty and stays there till i get gas again. sometimes when i start it the gauge will jump up to where im pretty sure it should be (3/4 tank with like 150 miles on trip o.) but drops almost instantly. ive resoldered my gauges and they all work except the gas gauge. it worked okayish untill i got my tank replaced a few years ago and ever since has been weird. i also tried adding some gunk remover like gumout and lucas and all they really achieved is giving me better gas mileage :) any ideas? das2123 11-06-2007, 08:27 AM Probably a bad fuel sending unit. It is located in the gas tank. Godofwarmike 11-11-2007, 11:06 PM ok easiest way to do that without wasting a lot of gas (with gas at 3.30 dont need to be spilling quite a bit on the ground) and im guessing its part of the fuel pump and to replace it takes replacing the whole works right? das2123 11-12-2007, 09:10 AM The fuel gauge sending unit (fuel level sensor) is attached to the side of the fuel pump module. The sending unit consists of a float, an arm, and a variable resistor (track). The resistor track is used to send electrical signals to the Powertrain Control Module (PCM) for fuel gauge operation and for OBD II emission requirements. denisond3 11-12-2007, 03:54 PM Its enough trouble to work on the fuel pickup assembly that I would replace the entire unit; and not have to worry about it for another decade. However if you are really energetic, you might be able to get just the fuel sender parts from a salvage yard. The salvage yards in different states may have some annoying requirements about letting you get parts from fuel tanks though. Godofwarmike 11-12-2007, 09:41 PM ok yea maybe ill snoop around some salvage yards and see if i cant find some parts. it might just be easier to get gas at the end of each week. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
