can i re-use short block after timing belt snap?2000izusu 11-04-2007, 02:31 PM hey everybody! new in neon land! i just came across a 98 sohc that snapped a timing belt what are the chances i can re-use the short block after the valve crunching that happened?:screwy: thanks! mike p.s. i know i will need a used/re-con head! rhandwor 11-04-2007, 09:35 PM Pull the head and examine the pistons. If they only have minor damage it should be ok. I did a volvo 6 cylinder which banged all valves and it worked fine after a valve job with all new valves. A friend damaged a mitsubishi head when he put the timing belt on wrong bent all valves. I lent him a manual and he got it 1/2 correct the second time and banged 1/2 the valves. A 16 valve 4 cylinder engine. He put the belt on correctly the third time. A lot of new valves but the short block was alright. A lot of the time not all valves are bent. All my bent valve experience was on foreign cars. 2000izusu 11-05-2007, 12:10 PM i think i am going to reuse the short block. thanks for your reply. Automotive Network, Inc., Copyright ©2012
