Re: impreza legacy interchange performance parts...
Since the engines are the same from model to model, then engine parts that don't come in close contact with the body or frame should interchange. Things like plugs, wires, throttle bodies, intake manifolds, cams, short ram intakes, fuel rails, pulleys, flywheels, etc should interchange no problem, just make sure you're ordering parts for an impreza with the same engine as you have. Electronics are a bit trickier. Things like headers, CAI's, exhaust get questionable, and I couldn't give you an answer one way or the other besides that I'm guessing those things won't fit.
Exterior wise I'd be surprised if anything was interchangable.
