Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Cars in General > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-03-2007, 07:25 AM   #1
jupilerman
jupilerman Normal reputation
turbo diesel intercoolers on petrol turbo cars?
Hi all. i believe this does not make sense...? Cause diesels run at higher intake temp charge. not? Or does it make sense?
thanks
jup
jupilerman is offline   Reply With Quote
Old 11-03-2007, 01:11 PM   #2
Schister66
AF -Advisor
Schister66's Avatar
Schister66 Normal reputation
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: turbo diesel intercoolers on petrol turbo cars?
It doesnt matter what the intercooler was originally on, as long as it has a certain amount of area in order to sufficiently cool the intake air. It also depends on the turbo you're using. If the turbo is inside its highest efficiency range, you CAN run a smaller intercooler because less cooling is necessary; however, if youre running a turbo into the "death zone," then you might have problems.
Generally, you need an intercooler large enough for your needs regardless of what it was originally on..
The new build is underway...
Borg Warner S256 + 9.8:1 built GSR + E85 = 450whp Daily Driver
Schister66 is offline   Reply With Quote
Old 11-04-2007, 07:04 AM   #3
jupilerman
Thanks. Best to do the calcs first I guess. I thought that diesel ICīs had a different extruded core, giving lower efficiency. Since high eff. might not be needed, so no sense in higher production cost.
thanks
Old 12-07-2007, 03:21 AM   #4
drdisque
drdisque's Avatar
drdisque Normal reputation
Send a message via AIM to drdisque
A lot of Buick Grand National guys use the IC out of the Isuzu NPR commercial truck.
Dr. Disque - 2007 Mazda 6-S 5 Door
drdisque is offline   Reply With Quote
Bookmarks
Google
Web AF
