Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 11-02-2007, 04:44 PM   #1
mking6
mking6 Normal reputation
What should i look for? 1995 impreza
my girlfriend is looking into buying a 1995 impreza 4 cyl. auto with 76k miles... im going to go help her look at it but im unfamiliar with subarus and im not sure what problems if any i should be aware of... they are asking for 2900... blue book is 2500....
thanks is advance for responces
mking6 is offline   Reply With Quote
Old 11-02-2007, 04:52 PM   #2
freakray
freakray +1000freakray +1000freakray +1000freakray +1000freakray +1000freakray +1000freakray +1000freakray +1000
Re: What should i look for? 1995 impreza
Look for excessive engine noise, worn cv joints, leaking side shaft seals.
Look underneath and make sure it's AWD if that's what you want as pre-1996 you could get a FWD Impreza.
AF User Guidelines
freakray is offline   Reply With Quote
Old 11-17-2007, 10:56 AM   #3
luckybrand4u
luckybrand4u Normal reputation
Just like Freakray said for sure . I just sold a 94 Subaru Impreza with over 175,000 miles . These cars are the best if they were maintained and not abused too mutch . The standard trans for sure would be best being they have less electonics in the awd system. Autos seem to have more issues if they weren't maintained and bought used. But just to let you know my new 96 impreza outback has issues and still has never left me stranded. If you find a great used Impreza buy it its worth it. Some minor things to check though for down the road. Front engine timing belt , tensioner, idlers and seals, Water pump and oil pump gasket and seals. If you buy used check under the front timing cover for any oil leakage. Sometimes prior owners replace timing belts but nothing else in this area. I found this out soon after driveing this 96 and almost catching on fire from major oil leakage onto converters. This leak is common on these cars and if you buy used check it first. Also If its and automatic make sure the Trans temp light only comes on as bulb check at start-up. This should only bling a few to 4 times and go out. If it blinks like mine does 16 or 17 times be ware.
luckybrand4u is offline   Reply With Quote
Bookmarks
Google
Web AF
