Aarrrg! Oil In My Anti-freeze!!!!
BOMBY
12-01-2002, 08:47 PM
Greetings All!
Just after I checked to see where a moderate oil leak was coming from on my 98 Stratus, I discovered oil in my resevour tank! There was about a half inch on top of the anti-freeze. I then pulled the dip stick and found no water/anti-freeze mixed with oil.
My first thought was blown head gasket but usually anti-freeze enters the crank case not the opposite. Right?
If my problem is indeed the head gasket, will a compression test confirm my troubles? By the way, I had the system flushed and the oil came back.
Any and all comments will be greatly appreciated!
Thanks!
Brian in Minnesota
fleyba
11-03-2003, 03:14 PM
A compression test should tell you if your cylinders have been compromised. You get oil in the antifreeze one of two ways. Across a leaky head gasket or a slipped wrist pin or broken metal ring could have worn a groove through the cyclinder wall into the water jacket.
Sexy beast
11-03-2003, 03:39 PM
Has the engine overheated recently? because these engine heads tend to crack.
gramsack025
11-04-2003, 02:13 AM
yeah, these cars are Fu#ked... my car leaks both oil and coolant.
especially oil in the winter....
still could be a leaky head gasket BTW.
gramsack025
11-04-2003, 02:17 AM
also, if it was anything like a loose wrist pin, you most likely would of heard it wearing through your engine very noticably
