Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 12-01-2002, 07:31 PM   #1
JAMES125
JAMES125
Angry No Comunication Of Ignition 7x
1994 PONTIAC GRAND AM 2.3 QUAD4 NO COMMUNICATION OF IGNITION 7X AT TIMES ALSO CODE 35
REPLACED IGNITION MODULE COILS,COIL HOUSING AND
AND PCM AND REPLACED IAC MOTOR FOR 35 CODE STILL
HAS CODE AND WHEN LIGHT COMES ON COOLING FAN COMES ON
LOCKS SCANNER UP WHEN NO COMMUNICATION OF IGNITION 7X
CAR DOES NOT START WHEN IGNITION 7X SAIS NO
JAMES125 is offline   Reply With Quote
Old 12-26-2002, 02:25 PM   #2
Shortbus
All hail AF
Shortbus's Avatar
Shortbus +450Shortbus +450Shortbus +450Shortbus +450Shortbus +450
Send a message via AIM to Shortbus
Try replacing the crank shaft position sensor. Normally 7x and 24x were only used for the 3.1 engine. The 7x crank sensor is in the side of the block and the 24x crank sensor is behind the balancer, but that is only on the 3.1 engines. I don't know why you would get that code for a 2.3? Anyway the crank sensor is at the back of the engine on the 2.3.
Good luck.
Shortbus is offline   Reply With Quote
Bookmarks
Google
Web AF
