96 Neon a couple probsVizzionn 10-29-2007, 10:47 PM Hi all first off ive posted on here before about my guages not working and thanks to you all got a swift reply on how to fix them , but there not fixxed i have reflowed the conections hmmm prolly 3 times now they work for about a month and start acting up again . Ok for the secong problem is i can start my car up from go down the road it shifts from low 1 then it takes a little bit to shift form that point to drive and when it does it shifts kinda hard , could it be that the transmission filter maybe dirty and need changed or am i looking at a posible sensor or trans work . Thanks in advance for any info das2123 10-30-2007, 08:26 AM For the gauge problem, take a look at the actual connections...you may have to bend some to make sure you are getting a good connection. Have you checked your fluid level lately? Vizzionn 10-30-2007, 05:04 PM i check the fluids of the engine and transmission on a reagular basis das2123 10-31-2007, 01:06 PM Have you ever adjusted the bands? Might be time to as well as a fluid and filter change. Vizzionn 11-01-2007, 04:00 PM ive never worked on a tranmissionn internally so i wouldnt know how to adjust the bands but ill try the fluids/ filter change first sense its the cheapest to do :) das2123 11-05-2007, 09:00 AM You don't take the transmission apart to adjust the bands. Here, you these two threads.... http://www.myneonspeed.com/howto/howto_1stgen_atxfluid.htm http://www.myneonspeed.com/howto/howto_1stgen_atxbandadj.htm Automotive Network, Inc., Copyright ©2012
