Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
Become a subscriber. Browse a faster, ad-free AF. Instantly.
Automotive Forums > Cars in General > Car Detailing - oxidized headlights
User Name
Password
Register FAQ Member Map Calendar Surveys/Quiz Arcade Mark Forums Read
Car Detailing Discuss tips and tricks on how to keep your babies in top-notch shape.
Old 10-28-2007, 10:39 PM   #1
liquidkool
oxidized headlights
i have oxidized headlights. ive seen alot of products that can supposedly fix them. which is the best? thanx
liquidkool is offline   Reply With Quote
Old 10-29-2007, 06:40 PM   #2
dave92cherokee
dave92cherokee's Avatar
Re: oxidized headlights
I've seen that small mother's power ball thing used with a polish and it clear them up quickly.
dave92cherokee is offline   Reply With Quote
Old 11-09-2007, 10:07 AM   #3
Paul79UF
My bro did just that. He attached one of those buffing/polishing balls to his drill and buffed his old hazed headlights and they came out pretty decent.
Paul's Travel Pictures
Paul79UF is offline   Reply With Quote
Old 01-17-2008, 02:15 PM   #4
TRDboi
Search for this stuff called Plexus (I think) to polish your clear plastics
Car sponsorships and car sponsor information
TRDboi is offline   Reply With Quote
Old 01-17-2008, 10:08 PM   #5
dave92cherokee
TRD you should know by now that you should not post messages to threads that have been dead for 3 months as chances are that the original poster has found a solution to the topic.
Old 01-22-2008, 08:00 PM   #6
blazinrisk
Thing is dave, I've been perusing these forums for awhile now and had trd not posted that I would not have found that information, in which case I may have reposted an identical topic only to be chastized by someone like yourself for reposting an old topic. Iin short, just because the information may not be helpfull to the original poster, doesn't mean it isn't usefull for someone else.
blazinrisk is offline   Reply With Quote
Old 01-24-2008, 01:59 AM   #7
pantheas18
spot on.
especially when you search through pages of info with no finish on threads - frustrating
Thanks mate
pantheas18 is offline   Reply With Quote
Old 09-01-2008, 03:59 AM   #8
wade623
wade623's Avatar
ok i know this is a little old but i tried some chep tootpaste and a rag on mine it seemed to work it got most of the yellow out but what did you use with the ball?
btw, what is wrong with reopenig the topic anyways?
wade623 is offline   Reply With Quote
Old 09-09-2008, 12:37 PM   #9
bobss396
bobss396's Avatar
Send a message via AIM to bobss396
I agree, who died and made these guys the "dead post" police? If you can help someone else, post away. If someone gets bent about it, the forum should self-delete older posts!
Bob
bobss396 is offline   Reply With Quote
Old 09-09-2008, 01:06 PM   #10
Airjer_
I just did an article on this a little while back here it is.
For the past year I have been experimenting with different ways of restoring hazy and yellow headlamps to there original crystal clear appearance. This is an easy project for the do it yourselfer and would take approximately an hour or two to make them like new.
First step is to clean them with any mild detergent. Glass cleaner will work just fine. Next I tape off all of the painted areas that I don't want to accidentally hit with the sand paper. Now the fun begins. Starting with 800 grit wet/dry sandpaper I wet sand each lens until all of the degraded plastic is removed. You will see what I am talking about once you start to sand. I then clean the area again to remove any grit left over from the sanding. Then I go to 1000 grit wet/dry sandpaper and generously sand each lens again. You will start to see the lens get clearer as you sand. After wiping down the lens again I finish the sanding with 3000 grit. Again you will notice the difference as you complete this step. Now its time to polish.
There are many kinds of plastic polishes available. Maguires and 3M are pretty good, I personally use a product that Cornwell Tools has. This will be the most labor intesive part of the job. I have a mini polisher so it go pretty quick for myself but it can still be done by hand with the same results. Polish until crystal clear! You may notice a few places that you missed after polishing, just repeat the above steps and they will look like new.
Here are the latest before and afters. This was a 98 ford contour and took me about an hour to get them 99% perfect!!
Before
After
I realize you think you're right, but I know I am right!
Airjer_ is offline   Reply With Quote
Old 09-16-2008, 03:44 PM   #11
97TaurusGuy
97TaurusGuy's Avatar
Send a message via AIM to 97TaurusGuy
This is the same process I have used in my shop for a few years now with great results. I find the plastic cleaners a waste of time. The only difference is after the wet sanding process I use some rubbing compound on a wax pad just to get the fine scratches out. Adds maybe another 5 minutes to the process. I to use polish on them afterwords.
Before
After
"Save water, shower with a friend"
97TaurusGuy is offline   Reply With Quote
Old 09-28-2008, 10:02 PM   #12
gatoratoy227
i've heard of CLR being used to remove the oxidation on the head light lenses
any merit to this or another waste of time trick
NO! ,we can't stop here, this is bat country. Raoul Duke
gatoratoy227 is offline   Reply With Quote
Old 09-29-2008, 12:14 PM   #13
Airjer_
CLR dissolves Calcium, Lime, and Rust, hence CLR. The headlights are not "oxidized" as much as the plastic is degraded from exposure to UV rays. I don't see how CLR would remove the degraded plastic but anything is possible?
AF Assistant
These Ads Open in New Window
User Name
Password
vB code is On
Google
Web AF
© 2000-2008 AutomotiveForums.com | Privacy Statement
