Trooper 94-changed alternator now have no lights and powerWebraft 10-28-2007, 01:57 PM The alternator in the issuzu trooper 94 was bad. I put a new one in. The battery is fully charged. Placed the key in the ignition and there is no light, no power of any sort. Same day, before I replaced the alternator, the door locks stopped working....I have the kind that you lock all doors with by placing the key inside the driver's door. I suspect the alarm system is shutting down the power altogether in the car. Or some of the fuses or sesnors that control the car power may have gone bad. Like I mentioned, even my headlights don't work. I am no where near a dealer, could anyone suggest any solutions? I appreciation in advance. JZ boritz 10-28-2007, 04:54 PM It may sound obvious - but - have you reconnected the battery after replacing the alternator? [EDIT] And are the other ends of the battery cables connected securely to their respective mounts? [END-EDIT] If the battery IS connected - check the main (high Amperage) fuses. Webraft 10-29-2007, 12:03 AM First, Thanks for you help. Yes, the battery connected and wires look secure. I will check the fuse. Is there a way to check it? since it is a fuse that you can't readily see its faults. JZ boritz 10-29-2007, 03:34 AM The higher amperage fuses have a window in the top - look for either a continuous bright metal strip (good), or a broken strip (blown). You could also place a multimeter (if you have one) across a removed fuse to check for continuity. Note, we are discussing the plastic box-shaped fuses with clear tops in the engine bay Relay and Fuse box. The fuses will be labelled on the lid of the box - there should be an 80A Main, a 50A Key Switch and a 30A ECM. I would first suspect the 80A Main. To remove a fuse, pull it straight up, off the two contact tangs. Don't confuse the fuses with the black relay boxes. [EDIT 2 Nov 2007] My mistake, to remove the 80A Main and 50A Key Switch fuses, unscrew the retaining bolts [END-EDIT] Webraft 10-29-2007, 10:16 PM Okay, the fuse is blown. I am on the way to get a new fuse. Any idea what caused the fuse to blow? I disconnected the battery, before I replaced the alternator. I suppose there may be a bad ground somewhere? I am going to pick up the fuse and install it and see if the car would start right up. I checked the battery with the meter and it is good. thanks again boritz 10-29-2007, 10:39 PM ...fuse is blown...Any idea what caused the fuse to blow?... I disconnected the battery, before I replaced the alternator... Can only be blown by too much current. Is the alternator (+) battery terminal and cable insulated correctly at the alternator end? ...I am going to pick up the fuse and install it and see if the car would start right up... Be mentally prepared for the new fuse to blow if you haven't determined why the first one blew - buy more than one! :lol: Webraft 10-30-2007, 12:44 AM I will recheck the connections and make sure that they are properly insulated. ************ Okay, I installed the new 80AMP fuse and as soon as I hooked up the battery, the fuse blew again. There must be a short somewhere causing the fuse to blow. Any suggestions? I suppose there is a chance that the cable connected to the Alternator is making a connection to something else beside the Alternator. I am able to see the connection to the alternator from the opening behind the front tire, but it looks okay. I really never had the old alternator checked at the shop, it just tested negative while it was still on the car. May be there is another element that is causing the mess? Thanks in advance for your assistance. I feel like I am close to solving the puzzle. boritz 10-30-2007, 12:58 AM Yes, there must be a short to permit more than 80 amps to flow. Try disconnecting the battery (-) ground and search for continuity with a multimeter, between the battery (+) positive and a body ground point. Disconnect the alternator (+) wire to test if the short is going through the alternator. Webraft 10-30-2007, 02:10 AM Okay, on the first test, how do I do that? Do I use the meter between the battery + pole and the body ground point? is that just any point on the body? IF there is continuity, then I suppose my Alternator connection is not insolated? I will follow up as you suggested.....sounds very reasonable.....thanks, boritz 10-30-2007, 04:39 AM Yes, you're on the right track. Any decent ground points on the body or engine. I forgot to explain that, after disconnecting the battery (-), put in a good 80A main fuse, since your test circuit will need to pass through it. Remove the fuse if you reconnect the battery (-) without finding the short, or it will blow. What you are trying to find is the short-circuit path for current to flow from the battery (+) to the ground point and back to the battery. You will need to disconnect any connection which is in a suspected short-circuit path to test if it is the culprit. I assume that your lights were working before you removed the alternator? Because you have been working on the alternator and it's connections, these are the prime suspects for the short-circuit. Webraft 10-30-2007, 09:52 PM Great directgions....thanks again. As strange as it may sound, I am having trouble finding any nearby store that carries the 80 amp fuse. Will look else where tomorrow. Webraft 10-31-2007, 12:41 AM I reached on top of the Alternator and loosened the nut to release the cable; I turned the contact around so that it had no chance to come in contact with anything else. I placed the nut back on and made it tight. I then pulled the insualting boot on top of it. The other connection to the Alternator looked good and appears to have and no malfunction. (I have a good fuse inplace) I have the battery + pole connected and - pole hanging loose. I used the meter with the red probe touching the + battery and the black probe touching the engine body or the car body, I get continuity. Does this mean I have a short in my Alernator cable? boritz 10-31-2007, 03:48 AM ...Does this mean I have a short in my Alernator cable? Very possibly; or worse, a short inside the alternator. Disconnect the cable at the alternator and ensure that the cable end is isolated from the body/engine. Repeat the test from the battery (+) pole to a ground point - if there is continuity there must be a fault along the cable. If not, test from the alternator (+) connector to a ground point or the alternator body - if there is continuity there must be a fault in the alternator. Check the plastic insulating pedestal on the alternator (+) connector to ensure that the bolt is not contacting the alternator cover or body. Webraft 11-01-2007, 02:58 AM have been swamped with work and other Misc. stuff....hope to get to work on the car tomorrow AM. boritz 11-01-2007, 06:27 PM Hope that you will beat it soon. Just correcting myself: you have obviously discovered by now that I erroneously said above that the 80A Main can be pulled out - it can't - you have to remove 2 screws. Webraft 11-01-2007, 09:08 PM I am happy to report that I got the car working and able to get it back to my driveway. Of course, besides the great help I received from this forum, I had the support of my 9 yeard old son and his good ideas. I am thankful to all of you for taking the time and walking me through the steps. I couldn't have done it without your great directions. Special thanks goes to Boritz for staying with it. I was about to take out the alternator, right before you guys provided more details for locating the short.... those tips really really paved the way. I had checked all the grounds and the wires and they all looked fine. There was a short at the Alternator where the pedestal is located. The edge of the connector was touching the almost attached other car metal parts. I was able to isolate it and that is when my son said "dad try starting it now". Now, I hope that the car would function fine when I take it to work tomorrow. My fear is that there still is a bare wire somewhere and by me pushing cords/cables around to look for short, I have temporarily dudged the bullet.:nono: boritz 11-02-2007, 02:20 AM That's great mate - glad you've got it going! copter steve 11-03-2007, 12:18 PM Good Morning Your issues with your trooper has made interesting reading. I'm not sure I am getting how you are looking for the short. This is the way I would do it. Take a test light, you know the unit has a alligator clip on one end of the wire and a probe with a lite on the other end, used for finding power thru the wire of a circuit. I take the negative cable off the battery and hook the alligator clip to it, then take the probe end and set it on the top of the negative post. Make sure all the doors are shut remove any lite under the hood. If current is moving because of a short, the lite will come on. Start removing fuses one at a time when you pull a fuse and the lite goes out you have found the circuit. I normally get a friend to help out with this process. It works really well. A dvom works the same way, attach one end of the meter to the negative cable and the other to the negative post and you will get a reading thru the meter, must be switched to the d.c. volt side. Good Luck Coopter Steve Webraft 11-09-2007, 01:23 AM Thanks, great suggestions. I'll put it into use. Automotive Network, Inc., Copyright ©2012
